springs w/ LCA's + UCA's
RE: springs w/ LCA's + UCA's
ORIGINAL: dvs_03gt
so stiffer up front does? and its worst?
stiffer in the rear = better?
would SPRINGS really matter, arent they just more so for body height? i mean if you have other good suspension components like shocks and control arms. will it really make your stang lack at its launch..
ORIGINAL: wwmost
lowering springs actually hurt you at the strip. you want softer up front soo you can get alot of weight in the back during your lauch and get traction. but if you have a soft spring in the back it will compress you willl loose some "launch" i guess thats the word.
ORIGINAL: dvs_03gt
ORIGINAL: dvs_03gt
Well than.. i think you answered my question. i really like the look of the sportlines, but im thinking twice. because they are so soft in the rear (140-295)lb/in). What i like was that the fronts.. are a nice rate; (425-630)lb/in)..after looking at the spring conversion tables again, which someone gave me in the past replies, I am sort of realizing that the H&R SUPERSPORTS are just a better spring?? They offer a semi-low drop with way stiffer rates in the rear (275-300)lb/in) but with alot stiffter rates in the front (700-760). is it that much of a difference? BETWEEN THE TWO? or not. thats about my last question.. will the supersports make my car over all better, or will the sportlines do the job for the low looks and still hold a powerful launch. BECAUSE YEAH I AM GOING TO S/C very soon.
ORIGINAL: wwmost
ORIGINAL: dvs_03gt
IcIbanez661
09-28-2006 10:55 PM
