Limp mode
Limp mode
Hi I am pretty new to theese forums
I have a 96 GT vert and I recently put flowmaster 40's on it, ever since then the check engine light has been coming on and off from time
to time. Is it true that when it is on I will have significantly less hp. Because I dont really notice any difference.
RE: Limp mode
depends on what code its throwing but the odds are in the favor of a limp mode. Also, I highly doubt just the addition of the mufflers is causing your code to be thrown. Take it to an autozone and have them tell you what code it is and go from there.
RE: Limp mode
ORIGINAL: Asspire
Did you have them welded in? If so did you disconnect the battery, computer, coils, etc?
RE: Limp mode
sorry It took me so long to reply, Yea i had them welded in, i doubt they disconnected the battery or the computer or anything
i guess ill run it up to autozone tommrow. how much do they normally charge to check which code it is.
jpplaw
08-22-2015 09:29 PM
