stroker kits
stroker kits
ive thought about getting a stroker kit for my 4.6 im lookin on the vtengines.com right now at the 4.6 to 5.0 conversion stroker kit. says starting at $2395.00. is that bad price and what kind of gains would i see ?
RE: stroker kits
Not worth it unless you are going to build the motor N/A or run some sort of FI. On a stock engine you will see little or no gains. The stock heads and cams will not make power in the RPM range the forged assembly will allow you to run.
RE: stroker kits
ORIGINAL: PerformanceRed4.6
the stroker kit along with heads cams intake. what kind of power would i see...also plan on building for nitrous....
RE: stroker kits
ORIGINAL: 2000GT4.6
RE: stroker kits
ORIGINAL: dlazrael
What about the stock 32v heads/cams? :-p
ORIGINAL: 2000GT4.6
Code spent a ton of cash on extra stuff to make the motor 100 percent bullitproof. It is really easy to just start bleeding cash when building a n/a 4.6.
The forged stroker assembly is simply not worth it until you do something with the heads and camshafts.
jwog666
12-27-2021 08:09 PM
