Clutch pedal problem
Sup guys,
I was driving home today and i noticed that my clutch pedal is vibrating. This has never happened before. I do have a 4.10 but I have been driving it around with that gear for a couple months. Anyone know why this is happening to my pedal. Took it to the dealer they told me that it might be worped but he said it should grind in every gear. SO no one knows whats happening. We also checked the pressure plate and that wasn't it.
thanks for the info
99 cobra
thanks for the info
99 cobra
RE: Clutch pedal problem
Does every person have this problem tooday or what. im just going from the problem i have had and seen. my clutch pedal vibrated when youre driving and lightly touch it with youre foot you can feel it. i would recommend a new clutch cable with adjustable ****, make sure its not plastic because they break. replace the cable and adjust it. I also had to replace the throw out bearing because when the pedal was pushed down there was no noise but when the pedal was depressed a strange noise was there. So thats my opinion. There is a FORD TSB on the noise and pedal vibration
Hey man i made this a long time ago. I just copied it and moved it here. So you think it is my clutch cable. Do you think i should buy one from ford or get a aftermarket one? Thanks for the info Yea i saw it on the tsb but that won't do anything for me.
99 cobra
99 cobra
Well, i am a FORD tech. So i belive in only factory parts. But owning a Mustang i know its hard to keep youre hands off from aftermarket parts. I would buy a OEM FORD part. But you could also depending on youre income and mileage, Buy a Clutch kit and if i was to buy an aftermarket i would get a STEEDA clutch cable ( adjustable)
Are you sure that will fix my problem. Yea I have alot of friends at my dealer so i get discounts on parts. Which one do i need to get from steeda. Steeda Clutch Adjuster Kits,Steeda Firewall Cable Adjuster,Steeda Double Hook Clutch Quadrant,Quick Release Clutch Quadrant,Adjustable Clutch Cable 96-02(IT MUST BE USED WITH AFTERMARKET QUADRANT.)
99 cobra
99 cobra
i cant gaurentee but i will say it has fixed mine and others. If you have buddys at the dealership ask them to go to www.fmcdealer.com and print you the tsb for it
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 11:50 AM
