Important, please respond
RE: Important, please respond
I dont see how injectors would help unless you have done something to lean your mixture out and you dont want to tune it...
then you could put injectors on it to richen it back up....
i think....
i think....
ORIGINAL: Derf00
no need to upgrade factory injectors unless you get blown (S/C or Turbo) same goes for the TB. Wasted money on useless mods. Work on the exhaust first, port and polish your existing intake manifold and head next, then go for other things...oh yeah, gears in there somewhere too.
i just dynoed my car and i have full bolt ons, nothing else i can do NOTHING then i added cams and had to be leaned out cause i was running too rich with cams.....so you have a ways to go before you will need injectors... and if you use nitrous you may STILL not need bigger injectors but just a bigger fuel pump
code3gt has one heavily modded/built n/a motor and he's about the only one i know of who has upped his injectors.
If you have full bolt ons and absolutely must install new injectors, then buy the 21# bosch/ford units that came on 03/04 GTs (not sure if there were other years).
