Underdrives with AC on, awesome!!
Used my AC yesterday, it hit 87 degrees here. First time I've used it since installing the Steeda UDP's, my AC was icy cold and I didn't feel the compressor cycles tax the engine like I used to. I don't understand why Ford doesn't use them as standard equipment, I'm sure they improve fuel economy.
John
John
RE: Underdrives with AC on, awesome!!
ORIGINAL: macdaddyslomo
A little O/T, but can you just get LIGHTWEIGHT pulleys for the 4.6, rather than UD ??? Less rotating mass would still be less parasitic loss
ORIGINAL: VARifleman
Once they get spinning, it's no longer parasitic loss due to mass. Changing the speed of them loses a little, but most of the problem comes from turning the accessories faster than they need to.
Once they get spinning ??? Once they get spinning who cares if you have 50hp or 500hp ??? It doesnt take lots of power to MAINTAIN a speed. Reducing the parasitic loss allows for you to see more power at the wheels....The MAIN reason UD pulleys will show a gain is the fact they are MUCH lighter than stock...underdriving them usually causes unwanted problems
I'm talking about once the damn pulleys start spinning. And if you think it's just because they are lighter, you have to think, what's taking more energy to drive, just overcoming the pulleys moment of inertia, or the fact that putting larger pulleys on accesories, since they require less torque, require much less force because your moment arm is longer. Who on here, with UDPs, has a problem with them because they are spinning accessories slower? You're arguing with an engineer here you know...
Need an example of someone that WOULDNT want UDP's but could use a lightweight pulley ??? Ask anyone who has a supercharger or a serious power audio system.
