supercharger, buildup question
ok i have a paxton novi 1000 reverse rotation supercharger 5-8 PSI on order and i know i won't hafta build the bottom end but do i need to do anything to the top end of the motor befor i install it all i have now is a K&N CAI and full legnth headers and an exhaust.
RE: supercharger, buildup question
i wouldn't think you would have to be to concerned about the top or bottom end , unless you are running more than 10lbs of boost just to be on the safe side i wouldn' run more than 8lbs of boost. but i have heard of people going to 10lbs. good luck..
ORIGINAL: hotrodV8
ORIGINAL: DIVER8374
^^^^Sorry to say but this (K&N CAI) is worthless when you install the S/C, you will not be useing it
ORIGINAL: hotrodV8
no s**t all that was was a list of whats on it now. i hate people who write stuff on a post when they have no idea how to awnser the question but want to put there 2 cents in even though it's worthless.
ORIGINAL: hotrodV8
Now i'm not a guru on forced induction but I think that you are going to need to soup up your fuel system which if I am right should come with the kit inline fuel pump and injectors but other than that it sounds like you got the rest takencare of.
