Ford C Springs
Ford C Springs
I am thinking of the Ford Racing C springs but I want to see them on a car before I order them. From what I understand I will not need c/c plates with these springs. I also want to make sure handling is improved. The springs also have to reduce the 4 x 4 look.
Anyone with these springs please post pics so I can see them installed. Thanks/Chris
04 Mustang GT 5 speed
SLP LMIIs
K&N Filter (air silencer removed)
4.10s
SLP LMIIs
4.10s
RE: Ford C Springs
you will not need the c/c. handling will improve. 4x4 look reduced. the front will go down more than the rear. I don't have pics. oh, and if you get an aftermarket midpipe with cats, it will scrap on a lot of speed bumps.
RE: Ford C Springs
ORIGINAL: redass02gt
RE: Ford C Springs
ORIGINAL: GTnAZ
isnt the eibach pro kit the same as the Ford C springs? both offer a 1.5" drop?
RE: Ford C Springs
ORIGINAL: LvGordo
that's what i got, the pro-kit and it is about 1.5", it looks so much better. However i am having some clunking and squeaking outta the rear end now. probably b/c i still have the stock shocks in there and they are bottoming. any suggestions on some good shock for lowered stang?
ORIGINAL: GTnAZ
RE: Ford C Springs
I looked at the pictures of your car. I think the stance before the engine swap is what i'm looking for. After the engine swap it looks like you have stock suspension. It might just be the pictures though. BTW you car still looks sweet as hell
RE: Ford C Springs
ORIGINAL: LvGordo
RE: Ford C Springs
ORIGINAL: 04DSGB
The pics before the swap are with eibach pro kits. They are not the same as C springs. I loved the stance and handling of the eibachs but I couldn't stand the speedbumps and somewhat harsh ride over bumps. Oh well, there's tradeoffs to everything. I would have kept the eibachs anyway however, when I swapped engines the front springs were not rated for the 4.6 and would have dropped the front further and risk even more speed bump damage. I sold and bought the C Springs.
I once scraped on a hard plastic speed bump and it melted onto my cats. That plastic stunk for a while.
