Installing Steeda Short Shifter?
I want to order a Steed short shifter for my 02 GT and was wondering how hard the install is. Do I need to have it professionally installed or can an idiot (me) do it? Do you need any special tools and how much do you have to tear apart to do the job? Any help is greatly appriciated. How good are the directions it brings and how bad can I screw it up? I have limited mechanical knowledge but I did sleep at a Holiday Inn once.
RE: Installing Steeda Short Shifter?
A shifter install is simple. The directions should be clear enough if you really need them. If you are mechanically inclined in any way, you shouldn`t have any problems. Just don`t pay someone to do it.
it is quite easy... the instructions that accompany steeda's shifter is quite thorough but very easy to understand... even i installed without any knowledge of mechanics =P
very simple. Pretty much 8 bolts you have to go through, 4 at a time. when going back together, you put some RTV silicone between the shifter and trans, and then put everything back on. very straight up install
