where did sticky go?
RE: where did sticky go?
Not sure where the sticky is but....
The only codes I know of off hand are...
Mustangtuning gives you 6% off with the code.... mustangboards
Stangsuspension gives you 10% off with the code.... 38stang
Hope this helps.
Hope this helps.
sticky thread was deleted for a reason that is not being released at this time. But basically your making the compaines lose money because some random person whose not even an active part of a forum can walk right in and use the codes. Coupon Codes are for preferred customers and repeat customers. How would you like it if EVERYONE in the entire mustang world knew a coupon code to your site?
LMP does not give out codes.
ORIGINAL: sprostang
Hope this helps.
Hope this helps.
