Which Headers to get?
I have a 2000 gt stock
only Mod is dual flowmasters 40's
want to get headers to get better airflow resulting in better MPG!
I don't want them to be loud thou just provide good air flow to the flowmasters.
Thank you guys for your help!
RE: Which Headers to get?
BBK ceramic long tubes are a good deal, but mac long tubes are even cheaper. They're only 330 i think, but you will need a new mid pipe. Rember, x is more horsepower, and the h is more torque.
how is the H more torque.. and X more HP?? HP is a directly affected by Torque. In fact the mathimatical calculation is
HP = (TQ x RPM)/5252
that's why your TQ and HP curve alway cross at 5252
~Alf
~Alf
ORIGINAL: Oscar_3748
ORIGINAL: djdalfaro
I'm still confused... cuz if your mid range TQ is higher on an H pipe than your HP is also higher, and if your top end HP is higher on an X, than you TQ is also higher. Correct?
when you change the headers shorties give you a hp that up higher. you torque curve also gets moved up in the rpm's but you lose some. same with the h-pipe which i run. both change where the hp and tq curve come on. in actuality theres really not much difference 3-5 max. the x-pipe helps with scavenging pretty much taking the exhaust from both side and equaling them out in where they cross. the h-pipe makes it so that it balances the 2 but not equal. it doesnt pull the exhaust equally out of both sides. at least thats what i believed someone please correct me if im wrong but i think i have the basics down.
