PCV puking oil
PCV puking oil
Ever since i had my cams done, i have been smelling burning oil. I thought it was my valve cover gasket(s) but i looked at the pcv on top of the passenger side vc and there is an obvious oil leak as there is oil around the base and the vc has some on it. When i get on the car, i can even get smoke from under the hood for a second or two, then it goes away. Is it just a simple case of replacing it or is it indicating soemthing else? I tried to push the top on to see if it was loose and it wasnt. I am not mechanically inclined so hopefully it is just a quick swap. help.
RE: PCV puking oil
also the PCV valve on the passanger side and the direct intake from the driver suck oil into your intake as well. I went the got a air water seporator and hooked bolth of them into the one side of it and a single to the intake and pluged the hole on the upper intake and that seems to be working great.
RE: PCV puking oil
ORIGINAL: 2VNA
i appreciate your help but didnt understand any of that.
RE: PCV puking oil
i had oil draw thru also.
http://www.jegs.com/webapp/wcs/store...tegoryId=16163
i use this JAZ mini breather can...there are others catch cans w/ no breather if your not going to open air.
