70mm or 75mm?????
70mm or 75mm?????
i wanna get the accufab intake plenum and throttle body..my engine is pretty much stock right now as it sits..i plan on a c.a.i. and headers in the future,,which mm would be better for my application? the 70 or the 75
RE: 70mm or 75mm?????
if you never ever plan on running any sort of FI, 70 mm.
If you do, 75.
Either way you will probably not see a difference. BTW, MM&FF showed almost no gains with their NPI car when it was stock doing the intake boltons.
If you do, 75.
ORIGINAL: kontroldkhaos
headers are a good choice though? right?
[IMG]local://upfiles/30741/27C3645B67CE495DAC417016277E8603.jpg[/IMG]
ORIGINAL: nitestalker
biger is batter go with the 75mm you need all you can get
If you cannot flow enough air to take advantage of the bigger t/b you will decrease your airflow speed, and lose horsepower. This is akin (though not to the same extreme) as running extremely large aftermarket heads on a stock displacement engine. You simply do not have the flow to use the size of your parts.
This is espcially true on a NPI car.
I have seen horsepower and torque losses from t/b and intake tract stuff being to large. I will have to dig out the copy of MM&FF where they did redheaded stepchild for the first time, and put the intake stuff on. I think they even ended up taking it off because they lost too much power under the curve.
ORIGINAL: Dragon02GT
75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75 75
To the stickies my friend
click me...please
click me...please
All of these are on PI cars......
ORIGINAL: 2000GT4.6
click me...please
click me...please
