OD on or off??
RE: OD on or off??
Yes, in a quarter mile you should never come close to shifting to 4th gear overdrive. No power in that gear anyway. The only way you would use that gear is just at the end of your run with something like 4.56 gears.
RE: OD on or off??
even if you had 4.56 gears, you're tranny wouldn't shift into o/d at WOT.
I think we've come to the conclusion that o/d on or off doesn't matter if you keep the pedal buried because the tranny won't shift into o/d at WOT
