Fluid in shift case?
RE: Fluid in shift case?
Well I know thats how i filled my transmission. I poured the fluid through the shifter hole. So I would assume yes? I guess it would depend on how much. If it's like a little then it's probably ok but if its full then you could have a problem.
ORIGINAL: amoosenamedhank
i just changed mine and you change it from the side of the tranny. There are 2 holes on the side one at the bottom (drain) on at the top (fill) you use those so you dont overfill the tranny. IF i were you i would get under there and change it asap.
