AEM Brute Force Intake
Old 05-11-2006, 02:12 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
Default RE: AEM Brute Force Intake
if you have problems with the oil on a k&n, you have much deeper issues than your car. you should probably go back to pre-school and just start over.
if you want to save $$ for other mods, just buy a k&n drop-in filter.
redass02gt is offline
Old 05-11-2006, 02:43 PM
96gtwithpsi
96gtwithpsi's Avatar
are the mustang MAF a bare wire element or a lamanted element.
96gtwithpsi is offline
Old 05-11-2006, 03:13 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
I dunno what a lamanated element is, but the maf consists of two bare wires. you can clean them with quick dry electrical contact cleaner if you have issues.
Old 05-11-2006, 04:14 PM
gt96stang
gt96stang's Avatar
ORIGINAL: bsteen81
While at the speed shop today I had a long talk with the tech about this subject. First off, anything metal used as an intake is no good, heat saturation robs ponies. Second, the short ram air kits, do the same, pull in air from the engine bay which is worse than your stock intake, whether its plastic or not. The best way to go is the K&N FIPK II, or any similar plastic intake that draws air from the fender well. Now the difference is minute, 1-2 HP at MOST. So if your willing to give up that extra power for a chromed out engine bay, its your call.
K&N is a short ram intake... It just has a plastic heat shield, which most rai will have to protect it from the engine heat.
gt96stang is offline
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: AEM Brute Force Intake
