need pics from all you nitrous guys
RE: need pics from all you nitrous guys
first switch is arming switch second is bottle heater and the button is a purge and theres an blue light ont he little o that lights up when the nitrous is activated alone with my shift light next to it
ORIGINAL: NeFiLiM
yes it will use the nitrous when im at wide open throttle and because i have the window switch itl only spray at the certain rpms i set it at like 3300-5500 or whatever i set it at
ORIGINAL: so1o2k3
so it uses nitrous automatically when armed? that is suh-weet.
A fuel pressure safety switch is also a good idea but I believe the Zex purple box handles that electronically, correct?
yeah fast and the furious really gave many misconceptions of nitrous use. The Nitrous will only spray IF- it is at WOT, and between the set RPM range (window switch) and at the proper fuel pressure levels (FPSS)- that is if you have all the proper safety switches mentioned above which you should. BTW here is my switch setup- from Mustangtuning.com : You can also see the MSD digital window switch in the glove compartment-
Close up-
Close up-
