need pics from all you nitrous guys
Old 05-12-2006, 06:51 AM
  #21
miglet
miglet's Avatar
Default RE: need pics from all you nitrous guys
i drilled a small hole in the shifter bezel, stuck it in there.. works VERY nicely for me..cus if i need it, its right there.
miglet is offline
Old 05-12-2006, 12:05 PM
  #22
so1o2k3
so1o2k3's Avatar
I've heard that it's not good to use nitrous in the lower gears...is that true? Can you set it up to only be used in the higher gears?
so1o2k3 is offline
Old 05-12-2006, 12:09 PM
  #23
MustangChris04
MustangChris04's Avatar
nitrous is more fun in lower gears
MustangChris04 is offline
Old 05-12-2006, 12:16 PM
  #24
so1o2k3
so1o2k3's Avatar
would that be because it makes you spin too much?
so1o2k3 is offline
Old 05-12-2006, 01:19 PM
  #25
Sebski
Sebski's Avatar
Ive got a very simple st up but i dont know how to post a pic.. Soo essentially Im wearing the dunce hat
Sebski is offline
Old 05-12-2006, 01:42 PM
  #26
newb2000GT
newb2000GT's Avatar
ORIGINAL: so1o2k3
hey I've only seen nitrous used in the movie fast and furious when it was popular okay? I saw them use the buttons on the steering wheels.
It's okay with me so1o2k3, just trying to help spread factual information. At least you can say you learned soemthing.
Also, things to don't get all blurry and stuff when you're on the juice, you just get a warm fuzzy feeling when it pulls like a ****.
I'd recommend swinging by the Pipes/Boost/Juice forum and reading the nitrous sticky to help detox whatever information you may still remember from the Fast and the Furious movie, as with most movies it's about 1% fact and 99% fiction.
newb2000GT is offline
Old 05-12-2006, 02:08 PM
  #27
newb2000GT
newb2000GT's Avatar
ORIGINAL: so1o2k3
I would think that would be what people are worried about. You basically get a nice increase in HP #'s and a really nice increase in TQ #'s so if you can't hook in low gear, you'll light them up running n2o. The amount of these increases is based on the jetting that you are running. 50hp, 75hp, 100hp, etc. I wouldn't run more than 125hp on my stock 2v but others will tell you 150 is safe and even an occassional 175 won't hurt.
I don't think low gear is a no-no as much as low RPM or when you hit the rev limiter. When you hit the rev limiter, your fuel supply is cut - you don't want nitrous flowing without fuel. The window switch takes care of this by allowing the nitrous to flow only when the RPM's are where you told the switch to do that.
For example, if you have your window switch set at 3000-5700 RPM, it will only fire at WOT in that RPM "window".
If you launch in that window, you may have trouble hooking up. If you're a not-too-heavily modified street car, you're probably launching below 3000 and should hook before the nitrous hits. If you're still worried about it, make sure your arming switch is within reach so that you can flip it on after you've hooked or when you shift to 2nd or whatever.
Old 05-12-2006, 02:18 PM
  #28
bryanec
bryanec's Avatar
Hidden under the seat.
[IMG]local://upfiles/20114/05689B0C99134577B14017BC8D522512.jpg[/IMG]
[IMG]local://upfiles/20114/90F9A3BED2234C65B731F763B330CDC6.jpg[/IMG]
bryanec is offline
Old 05-12-2006, 02:19 PM
  #29
bryanec
bryanec's Avatar
Mounting locations.
[IMG]local://upfiles/20114/E25EE67C2FC042D7BC60B4535685AF22.jpg[/IMG]
[IMG]local://upfiles/20114/BA3D40DB10144FED936977438F9B9E80.jpg[/IMG]
[IMG]local://upfiles/20114/34801FF3247545599D972D0C1DE55A31.jpg[/IMG]
bryanec is offline
Old 12-27-2006, 11:04 PM
  #30
pigmie
pigmie's Avatar
hey dan way at the top ........... i opened your pictures and i noticed that your nx nitrous jet was in that one part that comes already in the bbk cold air induction....... i was gona put my nitrous nozel there but i herd it was too far from the throdel body is this true .... does it work for you????
pigmie is offline
drfister
05-03-2018 10:38 PM
Sandmanbjj
08-21-2015 12:38 PM
svtrosey
SVT Forums
08-15-2015 09:09 PM
dseg
AmericanMuscle.com
08-10-2015 03:29 PM
Quick Reply: need pics from all you nitrous guys
