running without a chip
I have an 01 Cobra and just had a procharger put in. I need to take my car to have it tuned. How bad is it to drive it without a chip? The place is only 15 minutes away and obviously I'll be very easy on it. Any thoughts?
Thank you.
Thank you.
RE: running without a chip
A chip advances and retartds timing under diff. engine temps and loads. Recalibrates air/fuel for the procharger. But since you already had a procharger, there prob. isn't a bunchload of diff. between the two for recalibration. Just take it easy.Take it easy. I know it's a hard thing to do when you have a new part, but you'll be fine. Your engine light will come on, but probably cause your running lean.
ORIGINAL: mhorvath24
Thank you.
Thank you.
This is of course if the car will start and drive at all.
ORIGINAL: PearlRyde
So Is the point here that the factory ECU has a set map and will not adjust for the extra airflow the procharger pulls across the sensor?
Lots to the tune really. If you get a good kit it is set to pull timing if the IAT comes up.
Its ALL in the tune. The tune is the difference between a 380 WHP car running badly and a 420+ car running safe.
ORIGINAL: PearlRyde
Thanks... Trust me, I know a good deal about tuning, But i figured that his cobra would be able compensate for the extra airflow.
like I said, there is alot more too it than just the airflow. Even assuming the stock maf would not peg on the stock program, the car would go boom.
