which cams do i need?
RE: which cams do i need?
you won't be able to get the full use out of the cams without doing some serious motor work. If you plan on building your bottom end, then go ahead and get the agressive cams, but if not, get the milder cams so you will get the most performance out of them.
270's. they lope very nicely, and work fine when degreed properly. ensure the cams DO NOT have the 5* timing advance from comp. a 274 cam would require valve reliefs. not worth it to pull the heads just to gain 3-5 hp up top.
ORIGINAL: BCisme
Bigger cams arn't nessicarrily better cams.
junior04
09-28-2015 10:53 AM
