pull the wires off on it and crank it for ten sec then let off... over and over.. it will take about 20 min.. do it until you get oil pressure. then start her up!!!
don't pull the wires off (don't have them), just un plug each ignition coil and do ask described. this will turn the engine over and 'run' the oil pump but not spin it fast enough or with too much heat to damage anything.
