brakes
RE: brakes
hawks are good but give you alot of brake dust!
Try so EBC green I have them and they are great no Dust, or Nosie
http://www.ajusa.com/cgi-bin/ebc/start?tid=overture-ebc
RE: brakes
yep. I just say that because I'm on a tight budget, and if it isn't broken it ain't gettin fixed. But when it breaks, it gets upgraded!
If you are gonna change the rotors, go for slotted. Cross drilled are prone to problems and don't do much good, but the slotted are actually better. And buy the best quality pad you can and you'll be set. Also give the brakes a mild bleeding when you do them as well.
You usually should get around 50k from brakes under normal conditions. Sometimes less, sometimes more, depends.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
