brake question URGENT
RE: brake question URGENT
ORIGINAL: energiesource
lol jackass
im serious though, is there any tool you can use at home that will work?
ORIGINAL: redass02gt
maybe try ootozone then.
The Search function on this site rocks.. You can find all of your answers there...
JT
You only really need Needle Nose pliers.. Some heavy duty ones..
Just spread them apart enough that the tips fit into the grooves on the piston face, and rotate clockwise until the piston rotates all the way into the bore..
JT
JT
Unless the threads are messed up, or the piston is ****-eyed in the bore, then the piston should move, even just a little bit...
Are there any signs that the rubber boot has cracks?? Have you ever had any diminished braking capability lately, like a spongy pedal??
JT
JT
