adding more hp to the stock block???
how much can the stock block really see? ive been running 440rwhp for awhile and i run the hell out of it at times without any problems whats so ever.... ive had the motor like this for 7 months. also, i just got a aluminum flywheel and a tranny with less drivetrain loss... so if i put down say 20 more hp and have 460rwhp, would that mess with the engine hp i already have and cause the motor to blow? i would think it'd be easier on the motor and less stress. also, if i put alki injection, will that make my motor safer with more hp or will it blow it from me running alot more power out of it? because with both mods, i would like to see 480rwhp out of the stock block or more.. but im wondering if this can be done without any problems.... since in not really adding boost or other mods, just colder air and lighter drivetrain.
RE: adding more hp to the stock block???
i have an 02 also how the hell do you get that much hp? what mods?
Vortech S-trim SQ-V2 with 10lb pulley
Aftercooler for the vortech w/ IAT located after the aftercooler 4 inch homemade boost pipe 90mm lightning maf 42lb ford injectors 310lph fuel pump FFRP 3.73 gears BBK LT headers BBK catted X pipe Borla catback steeda upper and lower control arms full length sub frame connectors steeda caster camber plates eibach pro springs blu thunder short throw shifter 75mm Accufab Throttle body C&L upper intake plenum all synthetic oils throughout drivetrain/engine water wetter in radiator (helps motor run cooler) 10% antifreeze/90% distilled water in aftercooler battery relocated to trunk Pro 750 TKO500 transmission built by MMR Fidanza aluminum 12lb flywheel mrt 700 clutch the car is still in the shop for the tranny, flywheel, and clutch. i pick her up tomorrow hopefully.... |
forge your block paul. then you can add like 700hp if you want.
ORIGINAL: rbstang forge your block paul. then you can add like 700hp if you want. you dont know how tempting it has been... but ive been wanting a suspension that is worth a damn before that since all i have are springs and control arms... |
oooo ya i think the stock block was only made to hold about 420rwhp... but people have taken it up to 450 and some have been fine but others have had problems...
you car sounds insane. If you forge it, it will be rediculous. :)
vortech would have been enough lol!! have you been to the track?
ORIGINAL: rjgstang vortech would have been enough lol!! have you been to the track? yea, i ran it at a 8.2 @ 89 or somethin like that and blew 3rd gear out... thats why i had to get the new tranny. i only had a 2.0 60' that time.. i hope to pull a 1.7 next time out... |
ORIGINAL: rbstang oooo ya i think the stock block was only made to hold about 420rwhp... but people have taken it up to 450 and some have been fine but others have had problems... that makes me feel comfortable if i push 460-480rwhp. :D:):) |
