All 4.6's post what you got!!
#21
RE: All 4.6's post what you got!!
are most of you posting SAE(corrected numbers) or actual output #'s? In any case, I have a 2001 Bullitt and have dynoed it recetnly with the following mods
-JEtChips chip which is actually for 2001 Gt setup
-march performance ram-air and underdrive pulleys
results:
265rwhp corrected to 250rwhp
295rwtq " to 278rwtq
i have had trouble hooking up on the **** pour tracks up here but there is a great track in montreal called sanair which i intend to try out with M/T' street...i know im very capable with decent 13's @ 100mph + having run a 14.25@104mph last year!
results:
#22
96 gt
s281e motor swap 20k miles aprx
vortech v1
vortech aftercooler
afm powerpipe
42# injectors
lightning maf
255lph pump
vortech super fmu
steeda battery relocation
glowshift boost/air fuel gauges
mgw short shifter
slp lm2 catback
mac o/r h
bbk chrome shorty headers
saleen replica wheels
not installed:
3.90 motive gears and bearing kit
billstein springs and shocks
mm cc plates
granatelli c/as
rear wheel spacers
probably missing a lot, i forget some of the little things, asically everything in the engine bay is either new or from the engine swap.
vortech v1
vortech aftercooler
afm powerpipe
42# injectors
lightning maf
255lph pump
vortech super fmu
mgw short shifter
slp lm2 catback
mac o/r h
not installed:
mm cc plates
granatelli c/as
rear wheel spacers
#24
2002 Mustang GT
Zinc Yellow
49,000miles
K&N
BBK 75mm Throttle Body
C&L Upper Intake Plenum
Magnaflow Catted-X
SLP Loudmouth Catback
Bullitt Aluminum Pedals
Steeda Tri-Ax
Cobra Brakes (Front/Rear)
BFG GForce Sports (245x40x17)
SCT2 (Fast Specialties)
Zinc Yellow
49,000miles
K&N
Magnaflow Catted-X
Steeda Tri-Ax
#27
I've got the items in the sig with 68,000 miles. Dyno'd at 256.8rwhp, 296ft lbs. No quarter or 1/8 times yet due to still having stock rear end. Damn Code, don't list your mods anymore. I've got mod envy.
#28
Blue 2004 GT 35,000 miles
Mods:
K&N FIPK2
75 mm TB and Plenum
Underdrive pullies
Diablosport Predator
Steeda Short shifter
Eibach Prokit
sitting on the floor waiting to go in:
Custom grind cams and springs from www.flowtechinduction.com
NX wet kit with Gen-2X
Gauges and gauge pod
Dyno'ed when everything is installed in the next month.
Mods:
K&N FIPK2
75 mm TB and Plenum
Underdrive pullies
Eibach Prokit
#29
2000 GT 5 speed
Sdeeda udp
steeda full length subframe connectors
JLT Ram air
Trick flow 75MM upper
Trick Flow 75MM TB
Granalli coil Packs
autolite 764's
Steeda timing advance
Steeda LCA's
Cobra R Y2K 18X10"
BFG G-force
steeda egr spacer
FRPP 373's
Bassani X
Flowmaster cat back
Steeda Sport springs
Steeda adjustabel rear sway bar
steeda bumpsteer kit
Steeda Tri-ax shifter
Full syn throughout
chin spoiler
Comming soon
BBK LT
BBK short X
new clutch
410's
Own mods
Antena relocation
4 fog lights
PCV and crank oil filter before intake
Spoiler relocation plates
I think that's it.
Sdeeda udp
JLT Ram air
Trick Flow 75MM TB
Granalli coil Packs
autolite 764's
Steeda LCA's
Cobra R Y2K 18X10"
BFG G-force
steeda egr spacer
FRPP 373's
Bassani X
Flowmaster cat back
Full syn throughout
chin spoiler
Comming soon
BBK LT
BBK short X
new clutch
410's
Own mods
Antena relocation
4 fog lights
I think that's it.
#30
1997 mustang gt 2v.
tubular k member
tubular a arms
coil overs.
90/10 struts.
aluminum driveshaft
4.56 gears.
31 spline moser axles.
ford trac lok 31 spline limited slip.
aluminum block
99/01 cobra pistons
steen racing ported pi heads
stage 3 crower cams 590/601
stock pi intake
c+l plenum
bbk 75mm throttle body.
30lb injectors
nos noszle nitrous kit. 175 shot
upper and lower control arms
stock t-45.
still got leather seats and air conditioner
stock ignition.
weld prostars.
11.97@116.39 n/a
10.79@125.79mph on nitrous.
IM in the july issue of muscle mustang and fast fords in the snap shots.
[IMG]local://upfiles/5212/70E9C2BD8FF44CAA873A9025D4C76B4B.jpg[/IMG]
tubular k member
tubular a arms
coil overs.
90/10 struts.
aluminum driveshaft
4.56 gears.
aluminum block
99/01 cobra pistons
stock pi intake
c+l plenum
30lb injectors
stock t-45.
stock ignition.
weld prostars.
11.97@116.39 n/a
