All 4.6's post what you got!!
RE: All 4.6's post what you got!!
sohc
35k miles
440rwhp
420 torque
8.2@88
Vortech S-trim SQ-V2 with 10lb pulley
Aftercooler for the vortech w/ IAT located after the aftercooler
4 inch homemade boost pipe
90mm lightning maf
42lb ford injectors
310lph fuel pump
FFRP 3.73 gears
BBK LT headers
BBK catted X pipe
Borla catback
SPEC stage 2 clutch
steeda upper and lower control arms
full length sub frame connectors
steeda caster camber plates
eibach pro springs
blu thunder short throw shifter
75mm Accufab Throttle body
C&L upper intake plenum
all synthetic oils throughout drivetrain/engine
water wetter in radiator (helps motor run cooler)
10% antifreeze/90% distilled water in aftercooler
battery relocated to trunk
latest mods....
tko500
fidanza aluminum clutch
new mtr clutch
new dyno numbers will come in a month or so...
35k miles
440rwhp
420 torque
8.2@88
90mm lightning maf
42lb ford injectors
310lph fuel pump
FFRP 3.73 gears
BBK LT headers
BBK catted X pipe
Borla catback
SPEC stage 2 clutch
eibach pro springs
latest mods....
tko500
new mtr clutch
02 gt - 50k
performance mods:
h-pipe
slowmasters
tri-ax
cai
tb/plenum
4.10s
lsd
eibach prokit
monroe shocks/struts
and a useless handheld tuner.
appearance:
mach 1 chin spoiler
mach 1 grille delete (have to re-install)
silverstar headlights
white face gauges
white face a/c panel
clear corners
50% tail light tint
coming soon:
panhard bar
sway bars
subframes
performance mods:
h-pipe
slowmasters
tri-ax
cai
tb/plenum
4.10s
lsd
eibach prokit
appearance:
mach 1 chin spoiler
white face gauges
clear corners
50% tail light tint
coming soon:
panhard bar
sway bars
subframes
4.6L DOHC 35,512 miles
Performance:
Engine:
Diamond custom dished 10.5:1 C/R pistons
Mahle Rods
(stock) Forged Cobra crank
Ported and polished heads.
Comp Cams (Stage I) from Steeda
K&N Drop in filter
Air silencer delete
Air jug delete(only on mach 1s)
Exhaust:
Mac O/R Prochamber
Steeda catback (by borla)
Electrical:
Diablosport Predator Custom tuned
Driveline:
T3650 Steeda Tri-Ax shifter
Brakes
Hawk Highperformance street compound pads
Wheels:
17x8 FRPP Forged Alum Alloy Black Bullitts
255/40/17 Falken F451 Beta Tires (Front)
275/40/17 Falken F451 Beta Tires (Rear)
Appearance:
Steeda Race Wing
30% Window tint (Darn NC law)
Last Dyno: 381 rwhp 396 rwtq
Best ET(using D/Rs) 12.2@112.21
Performance:
Engine:
Mahle Rods
K&N Drop in filter
Air silencer delete
Exhaust:
Mac O/R Prochamber
Electrical:
Driveline:
Brakes
Wheels:
Appearance:
Steeda Race Wing
2002 Mustang GT Auto, 29,000 miles......Borla stinger catback, SLP catted X, MAC CAI, Accufab 75mm tb, Accufab plenum, Ford Racing 4.10 gears, Diablo predator tuner, Dyno tuned........249RWHP 295ftlbs Tq......8.89 @ 80 mph 1/8 (crappy stock tires)
ORIGINAL: racer02GTstang
sohc
35k miles
440rwhp
420 torque
8.2@88
90mm lightning maf
42lb ford injectors
310lph fuel pump
FFRP 3.73 gears
BBK LT headers
BBK catted X pipe
Borla catback
SPEC stage 2 clutch
eibach pro springs
latest mods....
tko500
new mtr clutch
sohc
35k miles
440rwhp
420 torque
8.2@88
90mm lightning maf
42lb ford injectors
310lph fuel pump
FFRP 3.73 gears
BBK LT headers
BBK catted X pipe
Borla catback
SPEC stage 2 clutch
eibach pro springs
latest mods....
tko500
new mtr clutch
