air fuel gauge ?
Old 05-29-2006, 11:59 PM
timi
timi's Avatar
Default air fuel gauge ?
i want an autometer a/f gauge. i'm gonna get the lunar series so it'l match the lunar gauge pod i'll get in the future. is there anything else i need when i get the gauge? is it difficult to install?
thanks!
timi is offline
Old 05-30-2006, 12:09 AM
mustang_montana
mustang_montana's Avatar
Default RE: air fuel gauge ?
i spliced mine into my drivers side o2 thats before the cats. i needed like 6 feet of extra wire for it but im not sure if autometer supplies you with that. install is pretty easy, i need to go back and make a switch for mine cause right now its wired into the headlight switch for power.
mustang_montana is offline
Old 05-30-2006, 12:13 AM
rbstang
rbstang's Avatar
if autometer is not wideband send it back. non wideband a/f gauges = light show. widebang a/f gauges = somewhat useful.
rbstang is offline
Tac2cul
Tac2cul's Avatar
easy to install
this is all depending on years mines an 01 so this is what i did
remove passenger side kick panel.....there u will see the PCM all the wires connect to it and u have to remove wire loom from the pcm to get in there...
u can connect to any of the front 02 sensor wires coming form the PCM
connect signal wire(usually yellow) to the gry/lt blue wire(#60) on wireloom thats for the right front O2
or
connect signal wire to red/blk(#87) on wireloom and thats for the left front O2
or
run wires all the way out to your O2's in the engine bay(way to much work)
then just find power when key is on and a ground and your set
by the way both wires are next to each other on the connector to the PCM
also i ran power from the traction control wires.....i tried using the defrost button and would get power until the key was all the way forward or something like dat...i forgot
Tac2cul is offline
Old 05-30-2006, 01:58 AM
03sonicgt
03sonicgt's Avatar
ORIGINAL: rbstang
+1
03sonicgt is offline
Old 05-30-2006, 11:31 PM
timi
timi's Avatar
thank you for the help guys!
timi is offline
Old 05-30-2006, 11:38 PM
randy78045
randy78045's Avatar
ORIGINAL: 03sonicgt
ORIGINAL: rbstang
+1
Ive heard these arguements before.... if ya wanna tune your engine with this gauge then youre making a mistake.... however, if you wanna know generally if your engine goes lean as it has in my vehicle (stuck float once and improperly adjusted floats in another case) this gauge just might save your engine... i dont know it this applys to fuel injection or not, but running your engine lean will destroy it really fast...
randy78045 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
StalkerGT
09-25-2015 02:41 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: air fuel gauge ?
