Chick with mustang needs help!
hey guys. A few months ago i invested in a 01' Mustang GT- 5-speed. I have added a few minor mods, with more coming....but i am having too many problems for my own good. I was about to try some new BBK pulleys, until i noticed a very strange whining noise coming from almost the center of the engine. I just replaced my serpentine belt, so im not quite sure if that could be the problem. Also, i was wondering if anyone knew how to make the cable clutch a little less grabby. Thanks for the help!
-Amy
[IMG]local://upfiles/39096/419C5C4B991B4F6791722A01D3D45E55.jpg[/IMG]
-Amy
RE: Chick with mustang needs help!
ORIGINAL: slow8
-Amy
-Amy
If not I recommend the UPR adjuster. You can change the pedal height which changes when the clutch catches.
Do you know if the clutch is stock or aftermarket? Because the aftermarkets clutches will be more grabby than the stock
Are you are talking about when it the clutch engages? If its its engaging to close to the floor, then the get firewall adjuster.
Edited: To be less drunkenly sounding. Cheers
If your pulleys are aluminum, I would return them and get a stronger metal. The aluminum pulleys actually get worn down by the belt which meens you have to replace them a couple years down the road.
