What RPM do Blowers start to kick in?
RE: What RPM do Blowers start to kick in?
i know that the eaton superchargers (roots) have a built in bypass valve. So, if one is to accelerate normal (even up to 4-5k) there will be no boost. When you accelerate fast the bypass valve closes, and the boost picks up. So, it makes more boost at lower RPMs, and is great for daily driving under normal conditions.
ORIGINAL: I_AV8_4U
Hey Stever...
The only experience I have with hairdryers was a Roots style 300 cfm Sebring that I had on a 1.8l MX-5. It didn't have the "turbo" lag of the centrifugal types, which I liked. It really felt like a v-8...a continuous powerband, if you will. I am assuming that it would be the same feeling on the V-8s. If you can afford it, I'de spring for a Roots. But, hell, ANY blower would rock!
BTW, I beat the hell out of it b-4 and after the supercharger. I got 30 MPG no matter what I did. Someone with one on a Stang could prolly let you know how it affects their MPG.
Good luck,
Troy
Hey Stever...
Good luck,
Troy
This is why you often see cars like supras etc that are very slow off the line or even from a 1st/2nd gear roll. The first couple of short gears do not allow the car enough time to get the turbo fully spooled, so you get "lag".
A centrifugal blower will make full power in every gear. There is no "lag".
WOT at any RPM in 1st or 2nd gear of my car (with the tires cold anyway) results in instant tire spin all the way to redline. There is no "lag". The only difference in the blowers is that if you start off in a higher gear (3/4/5) at low RPM the centrifugal will not have the instant pull of a twin screw or eaton, because it does not make the low end torque. However, throttle response is not effected, and the car will instantly make boost if you are in the proper (3000~ + ) rpm range.
Hey 2000...
"The only difference in the blowers is that if you start off in a higher gear (3/4/5) at low RPM the centrifugal will not have the instant pull of a twin screw or eaton, because it does not make the low end torque. However, throttle response is not effected, and the car will instantly make boost if you are in the proper (3000~ + ) rpm range. "
The "lag" I was refering to was the lag you said 'you' even get below 3000 rpm. By design, cintrafugal blowers/turbos are not instantanious in their spool rate. It does take (depending on the cfm) a bit for the blower to come to speed, which is where most of the power lies. That is why some cars that are twin screwed, will have a smaller primary ( to bite quicker) befor that air is spun in the secondary- this will effectively reduce most lag. If all you get is tire spin, try a wider tire with a taller sidewall for better tracion - you should feel the "lag" then! If you still don't feel the lag, then cool...that is the ideal set-up.
Troy
Troy
ORIGINAL: I_AV8_4U
Hey 2000...
Troy
Hey 2000...
Troy
If you do the same thing on a centrifgual car it will pull instantly (as soon as you apply throttle).
A centrifugal does not have to spool up like a turbo. The blower is belt driven, so if you are experenceing lag or "spooling" it means your belt is slipping, and thats a bad thing.
A centrifugal is simply designed to develop more and more boost as the RPMs rise. A twin screw unit is designed to develop boost at any RPM. But once again there is no "lag" and it does not take a "bit of time" for the blower to come to speed. like I said, if it is doing this your about to melt a belt
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
zanemoseley
09-06-2015 12:58 PM
