03-04 supercharger on 99 cobra
RE: 03-04 supercharger on 99 cobra
ORIGINAL: klingtacular01
does anyone know if its possible to put the 03-04 supercharger on a 99 cobra? if so, what needs to be done?
Alot. You might get it done for cheaper than a aftermarket blower, but it won't perform anywhere near as well as a stock 03 will. The eaton is a pretty weak unit that the 03/04 cobra's engine makes up for (much better engine overall)
ORIGINAL: ByPopularDemand
Wait a 99 cobra is at 320 hp/TQ right, so would it be that hard to get 70 hp out of an eaton
you sure arn't gonna do it with the stock eaton boost. It came with what, a 8 PSI pulley? I wouldn't want to run more than 10-12 PSI on a stock bottom end, no matter what the RWHP level.
The 03 has better heads and supercharger optimised camshafts. Hell, MM&FF dyno tested several 03 cobra engines with a n/a new edge intake, and they were making like 360-370 flywheel horsepower (no accessories)
Hmm so the 99/01 engine is diff than the 03-04 engine in cobras...Was it the 03-04 mach that was basically a N/A terminator
Heads/cams/bottom end was all different.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
