96 GT Fog Lamps
96 GT Fog Lamps
My car has the fog lamps and the wiring to plug the lights in but no switch to turn them on with. I know where the switch is supposed to be but all I have is 2 dust and dirt collectors (coin holders) in the center counsel. I've been told that there should be wiring for the switch under the counsel. Is this true or do I need to buy some extra wiring to get them to work?
RE: 96 GT Fog Lamps
Hmmm..I would pull off the center console and check to see if there is wiring there. Maybe the person before you had the fog lamp switch, but just didn't want it. So, maybe they took it out. I'm not to sure, but I would first check to see if the wiring is there.
RE: 96 GT Fog Lamps
I was told Ford did not put the switch in for some reason in the factory. I was trying to confirm that there was wiring under the center councel before I took it out.
Diode Dynamics
28
05-26-2022 12:02 PM
