Engine Dying and running rough on start up
I got new exhaust, headers throughout. My service engine light came on and of course its got something to do with my x pipe. Well I took the negative post off of my battery and the light went away(came on again a week later). Well my car seems to run rough on start up and it died today on my way to work. It just does it when it is first started. After it runs a block or so it runs fine after that. Any answers!!!
RE: Engine Dying and running rough on start up
You my friend need some MIL eliminators. http://www.mustangtuning.com/stmilel.html
If you have more money to spend, then you could get a predator tuner instead and it will do the same thing, and much more! http://www.mustangtuning.com/diablos...-mustangs.html
Hope this helps!
PS- If you are too lazy to try and read what they do, then I will tell you. They basically shut off your rear 02 sims, which are connected to your x pipe. They send a signal to your computer saying that everything is ok, and that you still have cats. Like I said b4, the predator tuner will do the same thing, except it can do a lot more usaefull things to your computer to enhance performance. Hope this helped.
Hope this helps!
bryan616fl
01-25-2019 09:07 PM
Design1795
08-24-2015 04:41 PM
