brake problems
Old 06-13-2006, 03:12 PM
ShadowDrake
ShadowDrake's Avatar
Default RE: brake problems
I had this same problem. No matter how much I would bleed them, the pedal would sink right to the floor and the engine would start to struggle. I ended up rolling it back in my driveway slowly and hitting the brakes to be sure I had stopping power, then going for a short (like 2 minutes, no faster than 35) drive, with light braking, as I drove the pedal improved. When I got back, I bled them all again, got a tiny bit more air out that was not coming out before, and all is fine now.
ShadowDrake is offline
Old 06-13-2006, 06:39 PM
josh00saleen
josh00saleen's Avatar
thanks for the replys.. Brake calipers are on correct w/ bleed screw pointing up. I have done several brake jobs just never ran into this problem. again thanks
josh00saleen is offline
Old 06-13-2006, 07:50 PM
Tac2cul
Tac2cul's Avatar
have you rebleed the system with it running yet?
give us some updates on what youve done since the advice
Tac2cul is offline
Old 06-14-2006, 12:22 AM
josh00saleen
I didn't have a whole lot of time. I did do some more bleeding w/ car running, and got some more air out. They seem to be getting a little better. I'll see tomorrow. I did call 2 different Ford delearships and both said that because of ABS system it had to be bled by their computer. I realize they want me in their to get my money, but has anyone else heard this? It is driving me crazy though, I want to drive my car so bad its killin' me. I buy a Saleen and drive it for two weeks and decide to powder coat the calipers and put d/s rotors on... I wish I would have waited now. Even though it does look pretty sweet. I'll post pics when done. thanks
Old 06-14-2006, 05:08 PM
Tac2cul
Tac2cul's Avatar
Yeah ABS can be biatch sometimes......
but i havent ever heard of it b4...but when i was checking around to get my calipers installed all the places i called asked if i had ABS and bleeding the system would be alil different. So i said screw ya i'll do it myself
Tac2cul is offline
Old 06-14-2006, 11:24 PM
josh00saleen
I got them bleed and they are like new again... thanks god.. A piece of advice for anyone removing calipers for whatever reason, get 4 vice grips so you can clamp the line at all 4 calipers. This I believe would make the bleeding process MUCH EASIER.. I got it done though. I'll post pics as soon as I get a chance. thanks for everyones help especially you tac2cul. Your right on about having to bleed w/ car running.
Old 06-15-2006, 02:30 PM
GodAmGT00
GodAmGT00's Avatar
How do you actually bleed the brakes w/ the car running?? Did you have someone else there, or did you rig the pedal to stay down??
I've never bled a car's brakes w/ it running.. Wouldn't the brake booster cause some sort of interference??
JT
GodAmGT00 is offline
Old 06-15-2006, 04:37 PM
Tac2cul
Tac2cul's Avatar
yeah i had someone else there to help.......
not sure how the booster would interfere.....
Tac2cul is offline
Old 06-18-2006, 03:55 AM
Tac2cul
Tac2cul's Avatar
nevermind
Tac2cul is offline
Old 04-12-2007, 03:17 AM
pete1665
pete1665's Avatar
i know this is an old thread but,,,
is there any truth to the special bleeding procedure for abs?
pete1665 is offline
Quick Reply: brake problems
