iF U FIND A GOOD SHOP THEYLL MAKE IT WORK WITH LONG TUBES THATS WHAT IM DOIN. WOOPS CAPS but i have a x mid pipe and they sayd theyll make the long tube fit
sweet... did any body put the mid pipe on by their self?????
I actually didn't, but I WISH I would have. I would have saved A LOT of $$ on the installation. Its really not that hard at all, just need some clearance under the car, like a jack, jackstands, or ramps would probably serve the purpose the best. Just be VERY careful, have someone with you when you do the installation, in case something goes wrong with the supports, NEVER do it alone.
Other than that, its somewhat easy, I would definitely try it yourself. I spend WAYY to much money on the install for my exhaust system.
I will be doing the catback install myself on my Corvette when I get it. No more paying for installs for me!
no, but be ready for stubborn nuts/bolts. have an oxygen/mapp gas torch on hand so you can heat them up to remove them, other than that just be careful. You will have to remove the pass. side 02 sensor first before you can remove the exhaust connections there
