Thermostat question
Thermostat question
I put a 180 degree thermostat in my car back in September when I switched my intake manifold out. Now that it is warming up outside (98 today), my car doesnt run anywhere near 180. It stays up around 205-210, and when I run my a/c, it goes up another 5-10 degrees. This is in traffic or on the highway. Is this a normal thing or should I maybe replace the thermostat and flush my coolant system?
RE: Thermostat question
yea I have an autometer water temp, fuel level, and voltmeter gauge. I just wanted to make sure this was normal because in the winter and most of the spring, my car stayed around 180-185 even with the AC on.
2 things you need to do to run cooler...
get a tuner, or if you have one, make the fan turn off at 181 and on at 189 or something like that.
and get an oil cooler, that will help your engine run a lot cooler. i got a tranny cooler on my auto and my overall engine temp dropped 5-10 degrees, since the tranny fluid returning to the radiator wasnt as hot when circulated.
cool, thanks for the quick responses guys, i appreciate it. Also, where could I get one of these oil cooler kits from? All i've seen just now looking for them is Automatic transmission oil coolers.
http://www.mustangworld.com/ourpics/fcar/oilcool1.htm
they have an article on how to do it, install and parts info =)
with my tranny cooler, and stock thermostat, i would guess im running around 190-195, about 2-3 lines before the middle. with the a/c on, in upper 90 to 100 degree weather.
i had tried a 180 thermo, it did keep temp down till i ran it hard or when the temp outside increased. you could see it flucuate from 3-4 lines before mid and back to mid.
stock i stayed on mid or 1/2 line before.
edit:
since the tranny cooler i can say my temp is consistent.
edit:
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
