bigger heat exchanger?
how can i put a bigger heat exchanger on my aftercooler? and wouldnt it be better cooling with it laying vertical instead of horizontal like how vortech has the brackets stock?
RE: bigger heat exchanger?
Setrab oil coolers is the company who makes the heat exchangers for vortech so I am also looking for a better replacement for my heat exchanger . I guess anything would work as long as the inlet and outlet are the same size . 3/4" I think right ? I'll look today and if i find one I'll post a part no.
I found the site . Just enter setrab oil coolers in a search engine , then look at the larger oil cooler they have with the dual cooling fans mounted to it ! It looks sweet . All you need then is the fittings to fit the lines which the have also . hope this helps .
sorry I was at the track . her it is I'll pm it to you also . Just click on oil coolers then proline oil coolers . and their # is at the bottom .
http://www.setrabusa.com/
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
