WHY
WHY
Have a 2002 GT sounds like rear end is making a howling noise when going around turns. also feels like its grabbing, but no problems in straight line on the road. Is this just my positive traction making noise; or could it be something real major.
RE: WHY
I know I'm going to sound like an ******* for this but..
Fords don't come w/ Posi-track.. GM's do...
You may want to check your axle bearings and seals.. Check your fluid level, it may be low, and when you go through a series of turns, the fluid could be drawing to one end of the axle..
If all is good there, inspect the spider gears, and ring/pinion gear mating surfaces for abnormal wear or burrs...
JT
JT
