problem putting on o/r H
I have a 99 auto and I can't reach to get the bolts on the passenger side that connects them to the headers. Something is in the wya I think it is the starter or somebody correct me if im wrong but do I have to take the starter out to get to those bolts or how else can i get to them?
RE: problem putting on o/r H
I removed the O2 sensors first, then sprayed wd 40 on the bolts.
If you can, get a 1/2 inch drive breaker bar, 12 inch extension, and a deep 15mm socket. Try to approach the nut as straight as possible. If you work at it you'll find the one spot where it works. One note: Support the rear of the h pipe as you remove the bolts, or have someone there to hold it up.
Good luck
Good luck
fu** the starter. Disconnect the battery (so yo udont' shock yourself) and remove the 02 sensor... then the bolts will be easier to get at
if you can't get them out (stuck) torch them to glowing red and THEY WILL come out
i had troubles with those as well
George
George
KEM Motorworks
08-14-2015 10:13 PM
