4.6 tranny question
4.6 tranny question
so i am going to do the 4.6 swap in my 65, mark VIII motor, but i want to go with a 5 speed, are the bellhousings for the SOHC and DOHC patters the same, basically im askin if i could put a GT 5 speed onto a DOHC 4.6....
RE: 4.6 tranny question
did you just have them reflash the computer or did you use the DOHC computer, b/c i am going with a Mark VIII DOHC in my 65 and im plannin on using the ECU from the Mark VIII and using a GT tranny and having it reflashed b/c they didn't come with manual transmissions in the Mark VIII
I did use the computer from the DOHC so I did not have to re flash. Did you get the engine already? If you didn't make sure you get the thermostat housing these are located off the engine on the Cobra's at least not sure if it is the same on the Mark VIII.
thanks, but i have been lead to think that i am going to have to get the computer reflashed b/c it was originally for a automatic transmission but i am going to put a T3650 5 speed so i would have to have it reflashed, or have i been mis-informed...
10-09-2015 03:27 PM
jaiidutch
09-14-2015 10:29 AM
