why only 1 wheel spinning?
RE: why only 1 wheel spinning?
going around corners and the traction lock disengages, so that's why around turns if you floor it you get a one tire fire... but straight line you should get both... mine does it with 113,000 on the clock gonna rebuild it soon too
ORIGINAL: jkgt3
That's odd, I have the same situation. I have an automatic and when I would get on it around corners my passenger tire would only spin. Now when I push the brake in and romp the gas both wheels spin. [sm=dontgetit.gif]
ORIGINAL: Colorado_Mustang
Sounds like your diff isn't working right. It may be time to rebuild the clutch pack.[:@]
ORIGINAL: GreyStang
Consider yourself lucky. If BOTH rear wheels spun while you were going around a corner, the whole car would wind up spinning out.
ORIGINAL: jkgt3
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
