Bad transmission or Belt Slipping or ?????
Old 07-07-2006, 12:52 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: Bad transmission or Belt Slipping or ?????
Majority of your parts on a car just need a few heat cycles with short cooling periods in between.
Sure sounds like your clutch is slipping.
Dan04COBRA is offline
Old 07-07-2006, 12:57 PM
P Zero
P Zero's Avatar
Did you do the self adjust thing on your factory quadrant? You pull up on the clutch pedal until it clicks, it then self adjusts. Anytime you do a clutch in a stang that shouldbe the FIRST thing you do after its together. Its either that it wasnt adjusted properly OR they used a solvent to clean the flywheel that leaves a residue. That is a common mistake when doing clutches, even carb cleaner will leave a residue that'll make a clutch slip.
If the clutch pedal clicks when you pull up on it, then your quadrant is fine. If it still slips then the tech did the work WRONG. I would actually get a second opinion.
-P.
P Zero is offline
mtgldr
02-03-2024 09:00 PM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Pyrate Dave
09-10-2015 07:30 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
09-08-2015 11:50 AM
Quick Reply: Bad transmission or Belt Slipping or ?????
