Exhaust leak maybe?
RE: Exhaust leak maybe?
Alright guys, its been a couple days, and i have a problem/question still. I bought a new stud from Ford, and i have a bolt for it, and the other day i tried putting it on.. Do i need to drop the entire h pipe, then screw in the stud from ON TOP of the headers, or can i put it through from the bottom..? My hand barely fits up to where the bolt is, so if i gotta go from the top, i have a problem.. Any help.. greatly appreciated.
If its the straight stud, passenger side, with the flats on one end you can do best from under the car. Make sure the threads in the manifold are clean, it should go right through the hole in the flange of the pipe and thread it in as far as you can, using the flats to grab it with pliers or something like that to get it tight. Then put some anti-seize on it and install the nut. Its not that easy but just take your time and you'll get it, good luck.
trashxtrash
09-20-2015 10:49 PM
09-10-2015 08:39 PM
