Removing Back Seat
RE: Removing Back Seat
or you could do it yourself with some plywood and car-carpet. just get the measurements and put the carpet on the wood, then cut it to fit and bolt it in with the existing screws from the backseat into the holes that are already there, probably alot cheaper and looks the same.
why would you take out the back seat? It cant weight that much . Unless you doing the whole car with weight reduction i would just leave it alone. Back seats are nice when you wanna throw some junk in the back. Just an idea!
ORIGINAL: Stinger
I was going to remove my back seat too. I am going to mount my subs and amps back there. My problem is I can't seem to figure out how to get it out. I'm feeling kinda stupid because I've done this with other cars without any problems. I'm sure I'm missing an obvious location to unbolt it. Any help would be appreciated. Thanks.
99-02 gt (far as i know-mine is 02) there are two push clips that just push in from just under front of the seat,like clips push those in while pushing down on your seat then lift up -good to go( had to do this when installing my Nx kit) lol
Shifty Magoo
08-25-2015 03:08 PM
dochawk
08-25-2015 08:25 AM
