im an idiot, mighta messed up timing, HELP!
ok here is the deal, my motor was sludged up and froze the timing tensioners, well when i went to take the timing apart when i let the passenger side tensioner off it spun the cam just a little, i didnt know i was supposed to a clamp to keep the cams from moving, anyways in order to get the cam ined back up i had to move it, could i have possibly hurt the valves by doing this also is there any possible way that i could mess up the timing even tho all the timing notches match up, i just dont want to put it all back together and have the timing off
RE: im an idiot, mighta messed up timing, HELP!
Just spinning the cam in place won't hurt the valvetrain. It isn't like you hooked it up to a drill and went for some high rpm's.[sm=badidea.gif]
If you lined everything back up to where it should be, you should be just fine.
mungodrums
10-07-2015 04:01 AM
TfcCDR
09-14-2015 12:08 PM
