Cams and S/C
RE: Cams and S/C
ORIGINAL: droptoppony
The VT st1NA cam would not be the best cam to have if your going blown in the future. You will lose alot of boost through the exhaust stroke. A few guys do have them but i bet they would pickup another 25-40 hp by switching to VT or Crower blower cams. Now Comp Cams NA cams are actually good for blown or NA. If you look at the specs they aren't far off VT's blower cam specs.
I know a guy who used Crower ST2 Blower cams in his NA application and picked up 30hp.
RE: Cams and S/C
ORIGINAL: LvGordo
you are going to lose boost with cams (or headers or p&p heads for that matter). If you are saying that you will lose more with a n/a cam vs a blower cam, i will take your word for it. The vt 1s are a good mild cam for n/a and seem to do pretty well when boosted. I would be curious to run a back to back comparo of a n/a and blower cam of same "stage" and see what the differences are.
When you lose boost from better flowing heads/exhaust etc thats a good thing because your engine is now more efficient and will work better.
When you run a NA Cam on a boosted car you lose boost because the timing is off because of the cam. The exhaust valve will open to quick and waste some of the power the blower is making. Thats why some guys gain as much as 60rwhp when switching to blower cams.
RE: Cams and S/C
Thats what i would do if i knew i was definately getting a blower later.
RE: Cams and S/C
ORIGINAL: LvGordo
you are slowly talking me into switching, however i think i am getting near the hp limit. I will say that when i did my cams, i thought s/c was waay off in hte future. but again, my car makes alot of power with the n/a cams, and no valve springs needed.
RE: Cams and S/C
i think my car # myte be off.. i have a head unit that is sappose to run an accurate amount of hp from the crank and you can also do rear wheels but i dont have the hook up + $450. But i only have wats listed below and it says im pushin out 390-400 to the crank when im usin stage 2 on the throttle body?
RE: Cams and S/C
and i also have steeda pullies
junior04
09-28-2015 10:53 AM
