Buying Drag Wheels
Buying Drag Wheels
I am trying to figure out which size to buy. I know the bolt pattern but I dont know what the backspacing is. Does anyone know what sizes I need for a full set of drags on a '98 GT?
RE: Buying Drag Wheels
the bolt pattern is a 5bolt 4.5".
The back spacing depends on the size you want but the rule is 6.5"bs for a 15x10, and 5.5"of bs for a 15x8
now for as a skinny, I have not heard of anything illegal about running a skinny. You just have to decide how much tire you want up front.
The 15x3.5 only comes with one bs. You will either need a 1/2" spacer upfront. or if you dont want a spacer, you can grind the caliper. Now if you want to run a smaller spacer than the 1/2" you will have to grind some, but of course not as much as with out a spacer.
99'up will need less of a spacer, just because theres alittle difference in the breaks than the sn95's.
