Winter Drivability
RE: Winter Drivability
ORIGINAL: 03sonicgt
I drove my 03 gt nearly everyday last year in the winter. You have to buy winter tires, it's a must. I would suggest getting a seperate set of rims and tires. With the traction control and winter tires and safe driving, a stang in the winter isn't as bad as they say.
I tried my stang in the snow ONCE. Was 2 inches tops, and it had all come down at once so there was no salt on the roads. Needless to say, NEVER doing that again. The traction control doesn't help when you can't even start it by going amazingly gently in 2nd gear.
... Then again I was also still using the factory, most importantly BALD tires. With a set of winter tires and a lot of weight in the back you should be ok if you take it slow, but I'd reccomending getting a $800 beater for the days there is snow/salt on the roads.
I've got an 03' GT 5spd and i live in IN, and i had my car in the snow a couple of times and i wwouldnt recomend it, given my tires wernt the best, ne small incline was a b**ch to go up
i drove my car 2 times in the winter and i will never do that again.....but it does make u a better driver thats for sure......my buddy drives his all winter tho, studded snow tires and a few sandbags in the back and you should be fine, just as long as the roads are not under 2 ft of snow
