if wd40 won't work, try pb blast... it's the ****.... also, if penetrant doesn't work, heat up the nuts/bolts till they glow red and they will come right out. I had to do this in 3 places when i pulled my pipe to do my trans. Hopefully when I go to put my o/r H on, they won't be as bad seeing as they were all broken loose.
ok, this may sound like a simple question to you guys lol but imn not sure. so the cats are completely replaced by the X-pipe?
yeah. the xpipe replaces the stock h-pipe that has the cats on it.
the x-pipe will not have cats on it if you get a off road version. but it is also offered in a catted version, the aftermarket cats flow better than the stock ones, and there is only 2 on the mid pipe compared to 2. If you like the sound of an h-pipe they have an aftermarket one also catted or off road
