safe jack points?
RE: safe jack points?
I jack the rear up first and place the jack stands underneath it and let the jack back down.. I have 2 jacks so I will jack one under the left arm right under the spring and one on the right.. If you only have one jack i really dont know what to tell you... Other than do one side at a time. good luck...
I know this doesn't help you one bit right now. In the future if you were to install a good set of full length, weld in sub-frame connectors, they provide excellent jacking and stand points.
[sm=alcoholic.gif]
[sm=alcoholic.gif]
i have 4 jack stands. since we are the subject of where to place the jack stands, if i were to do a spring install, where do i place the jack stands then? i cant place them on the axle cuz i need to get the springs out. and when i need to get the springs in can i jack the rear up using the diff? i know this is a no no but since there isnt gonna be a the whole cars weight on it cuz i will place the jack stands somewhere else.
ORIGINAL: wwmost
[sm=icon_guiness.gif]
jwog666
12-27-2021 08:09 PM
09-25-2015 09:06 AM
