Timing adjusters???
Timing adjusters???
Alright, Im about to get a Steeda timing adjuster put on and im wondering if it will cause any detonation if it is done wrong. Can someone give me a better idea about detonation and how it all works so I will know what im talking about when I go to get it installed. Thanks a lot!
RE: Timing adjusters???
i have one on my car and im advanced 15 degrees, i just gotta run 92 octane to stop pinging at hard accel, and high rpms. thats all just dont go past 15 degrees advance. should gain ya about 10-15 hp and trq it did for me. im running a 02 GT
it will cause detonation if done wrong. you'll have to run premium fuel, i'm sure the steeda manual will lay it all out for you (how much timing you could safley add). if you do it right, and run 91+ octane, you'll have no problems. give steeda a call, i'm sure they'll be happy to answer all of your questions.
you might have a problem if you have underdrive pullies in the summer since the car will be running hotter.
09-01-2015 08:16 PM
